Looking for a USB switch - Any recommendations?
Commissario
16 Oct 2002
In the radio shack
I need to switch a USB device between two PCs so am after a switch. There are loads and loads available so it's a bit of a minefield.
It needs to have one USB A port so I can connect the device there and two USB2 B ports for the cables from the computers.
Any recommendations please?
Thanks.
i was in this dilemma recently and needed one to control 3 machines, i went with:
Ugreen USB3.0 switch
Works well however downside being there is no automatic detection so it doesn't switch if it detects another active computer, its manual with a button on the device...
Having said that, noticed theres a device on Amazon which has a nifty IR remote to switch between devices, might invest in one of those and give it a go
Thanks.
You can link to them, OcUK don't sell USB switches so it's allowed :)
I don't really want USB3 though because the B connector is different.
Manual switching is perfectly good for me, in fact I'd rather have it that way because when I'm using it, both computers will be switched on so I want it to be able to control where it's connected.
Thinking this might do the trick.
Ahh yes that's one will do. I have the USB3 version of it. That one has no auto switch so all manual.
There is another with auto switching one which looks ideal. I was thinking of getting the 4port version but the button looks a bit ugly
https://www.amazon.co.uk/Sabrent-computers-peripherals-Indicators-USB-USS4/dp/B074TZKGVR/ref=sr_1_8?dchild=1&keywords=usb+switch&pd_rd_r=37704615-d086-4b6b-9d53-2f43732de780&pd_rd_w=P6S9n&pd_rd_wg=GcVHP&pf_rd_p=7c89f663-1851-4f5c-ad06-b2fd7b71af3e&pf_rd_r=165Z3M0JXNQZVGZABN06&qid=1629279980&sr=8-8&th=1
Then the IR Remote version is usb3 and has 4 ports so won't bother posting it
I've ordered it. Shame it comes with cables because I already have far too many and the ones it comes with are too long!
