Lifting very old floorboards
19 Aug 2019
Anyone have any experience with this? They appear to be nailed in. I've pulled out the wood filler from between one of them (it was falling apart anyway).
They appear to be nailed down in many many places. Youtube videos make it look very easy but I can't see how I'm going to do this without breaking/ruining the ones adjacent to it.
Are there specialised tools?
5 Aug 2013
Shropshire
I had to buy special tools to get floor boards up on my 1930's house
Hammer
screwdriver
chisel
circulare saw
crow bar
Plasters
book on learning some French sayings.
:eek:
17 Jun 2012
Try a nail lifter and chisel, just have to chisel around the nail head then get the lifter under the head and pry it out a bit, then claw hammer. Will take a bit of time and effort.
OP
19 Aug 2019
Chiselling around the nail would surely damage them, no?
I want to sand them, treat them and put them back in with the gaps equidistant.
Here's what I'm dealing with:
5 Aug 2013
Shropshire
with a gap like that this is where a spade chisel comes in - This is hand chisel not a drill one -then where the joist is put chisel in the gap and gently try and lift the board -having two would help or big screw driver -you might be lucky and nail will give or the nails will stay and go through the board - I don't know of any other way - it's been years since I lifted boards and they were T&G where you used circular saw to cut tounge off.
If the nails do come up with the board tap the board back down and nail might stay up -if so use a claw hammer to pull nails out
If the nails rip through you can just fill the holes with same colour filler or renail in old hole.
Must be a lot of draft coming up through those boards
Deleted member 66701
D
Why are you intent on lifting them up / treating them? Just lay some engineered flooring over the top.
OP
19 Aug 2019
Will be more costly, but would certainly be a lot quicker, and save the faff of having to try and pry out the nails.
Well there's no way I can lift them; they're about six inches in depth (see the video I just posted).
There are a lot and I rather like them; they're around a hundred years old.
21 Jan 2010
Definitely sand refill and treat. Looks like a lovely original floor.
Can you squeeze a wire down one of the gaps? Could get you the couple of plugs you want under the sofa?
OP
19 Aug 2019
Good shout.
I can :)
I'll need to use some conduit but I can send wires down there and have them pop up under the sofa which will be fantastic.
- Do you think I need to plane the edges of the boards too where the filler has taken away a bit of the wood?
- Any ideas how to get out all of the dust and dirt that's packed between the boards? Hoover only does so much .
- How does one sand into the corners? I checked the sander lender place and they have a separate sander "for edges." Which is a bit frustrating as means I'll have to rent two machines and I'm concerned results from one machine will differ to another.
21 Jan 2010
Good shout.
I can :)
On the edges I'd use some very coarse sandpaper just to quickly nip off the very lose bits. Don't go too hectic as you'll end up taking chunks out.
Dust and dirt - just push it down the hole. Don't worry about getting it out too much.
Corner sanding is only possible by either a corner sander or renting the separate machine. It'll blend in but worst case finish by hand.
I know you have a lot of depth to play with but don't sand more than the top half a mill off or whatever.
OP
19 Aug 2019
Good shout. How do I prevent sanding more than the top half mill? A setting on the machine I presume.
Would a corner sander be able to do the whole lot then? Not just corners?
I CAN'T PUSH THE DIRT INTO THE HOLE. I can't know it's down there. It's awful. There's so much. God knows what it is.
21 Jan 2010
Follow the instructions carefully and watch lots of YouTube videos.
Corner sander will only be sensible for corners.
Trust me, push the dirt and forget about it. You don't want to knacker yourself out on stuff that doesn't need to be done. :D I get the OCD angle but it's a waste of time!
OP
19 Aug 2019
Ok :)
Sorry; you said "Corner sanding is only possible by either a corner sander or renting the separate machine." I thought the separate machine *was* the corner sander. Unless you meant rent a person do sand the corners but, tbh, that's not a great way to put it. "Hire" sounds much better and you pretty much accomplish the same thing.
So, either way, I need two machines.
And getting the old filler out? Is that just a case of using a knife on hands and knees (which is what I've been doing thus far).
Do I need to buy a specific filler that allows for shrinking and expanding in hot and cold and also that allows for treatment? Ideally it'll be fairly close colour to the boards themselves.
OP
19 Aug 2019
Thanks all.
I've basically discover that they are at least 7" deep. that's right. My floorboards are 7" deep. Each one. So there's no chance of lifting them.
So I'm just going to sand them and then treat them.
Unsure whether to rent a massive sander or just use an orbital one myself. Probs the former.
Also need to look into treating price.
Question; what's the best way to cut a hold in a piece of wood when you can't get all the way through. A Dremel, right?
I want to fit a USB-C power hub in there but can't work out a way of doing it neatly.
