You should really know better Linux Fanboi, if you're looking for a 64Bit Linux arch what does it say?![]()
I'll just leave this here
*buntu
Real Linux users use Arch!
https://wiki.archlinux.org/title/Installation_guide#Acquire_an_installation_image
The original specification, created by AMD and released in 2000, has been implemented by AMD, Intel, and VIA. The AMD K8 microarchitecture, in the Opteron and Athlon 64 processors, was the first to implement it. This was the first significant addition to the x86 architecture designed by a company other than Intel. Intel was forced to follow suit and introduced a modified NetBurst family which was software-compatible with AMD's specification. VIA Technologies introduced x86-64 in their VIA Isaiah architecture, with the VIA Nano.
The x86-64 architecture is distinct from the Intel Itanium architecture (formerly IA-64). The architectures are not compatible on the native instruction set level, and operating systems and applications compiled for one cannot be run on the other.
