Hi all,
I've been thinking about moving to a WC set up for a while and finally decided to start chosing components. Currently my plan is to only WC the CPU as a start and see how it goes. I'm confident enough with the build process itself but a little unsure when it comes to components. As such, I used the EK build function to come up with the below, modified slightly myself to have the flat 120 reservoir instead of the suggested one.
Are there any glaring mistakes in the below setup? Would appreciate any guidance on potentially better (or better value) configs as I'm totally new to the process.
Cheers
Jon.
My basket at Overclockers UK:
Cheers
Jon.
- 1 x EK Water Blocks EK-Quantum Inertia D5 PWM D-RGB Pump - Plexi= £129.95
- 1 x EK Water Blocks EK-CoolStream SE 280 (Slim Dual Fan) Radiator= £58.99
- 1 x EK Water Blocks EK-Quantum Volume FLT 120 D-RGB Reservoir - Plexi= £64.99
- 1 x EK Water Blocks EK-Velocity AMD CPU Water Block - Nickel + Acetal= £65.99
- 2 x EK Water Blocks EK-Loop Hard Tube 10/12mm 500mm (2 pcs) - Clear= £7.99
- 8 x EK Water Blocks EK-Quantum Torque HTC 12mm Hard Tubing Fitting - Black= £6.95
- 1 x EK Water Blocks EK-ATX Bridging Plug (24 pin)= £1.99
- 1 x EK Water Blocks EK-Quantum Torque HTC 12mm Fitting Colour Pack (10 pcs) - Black= £10.99
- 1 x EK Water Blocks Filling Bottle (1000mL)= £6.95
- 1 x EK Water Blocks EK-Cable Y-Splitter 2-Fan PWM (10cm)= £2.99
- 1 x EK Water Blocks EK-CryoFuel Solid Cloud White Concentrate - 250 ml= £11.99
£8
(incl. VAT)
