Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
That's because Sony don't make the adaptor for the Canon lenses, it's not in their interest to. Canon however has all the blueprints so they don't need to reverse engineer hence it works like native and with mirrorless you don't need to micro adjust hence it will improves pretty much everything. The downside though it is so good, it will expose the optical shortcomings of older EF lenses. The R5 being such a high pixel monster it is quite revealing when it does so.
The other thing to take into consideration as you are switching mount, as I have done a few years ago, is the cost of the new lenses and accessories. The new Canon Speedlite for the RF mount is £1200, yes, £1200. The 600 EX-RT was expensive enough at £600 but this EL-1 is £1200!!!
https://www.canon.co.uk/cameras/speedlite-flash-el-1/
What Canon has so far is AMAZING AF, they always had great Dual Pixel so this is basically now that on steroids, their lenses are also excellent (although rather large compared to the competition), their ergonomics are also what I prefer. Their menu system works as you expect, Sony menu SUCKS. The LCD is also fantastic on the Canon, touchscreen too….Sony I am looking at you.
However, in the long run, RF lenses are not cheap, just take a look and see whether you want to go down that route as it will be the future if you get the R5. You could continue to adapt the lenses but eventually upgrading to native is on the cards, at least for your most used lenses.
And yes, the 35 RF isn't out yet, it's probably next as the 85 and 50 L are both out. I suspect that will be about £3k when it's out as well, the Sony 35GM is half that price at £1500.
In the end though, they are all excellent, I would go back to Canon but the cost of it is just too prohibitive for a full set of primes.
edit - correction, £1300 for the new Speedlite.
https://www.parkcameras.com/shop/canon-speedlite-el-1-flash-gun_1350141c
