- 28 Dec 2009
- Wales
I think curve optimiser -15 worked for me, if you want to get temps down further.
As you've found out, anything which maintains a single core load will keep the chip in a state where it will attempt to use PBO for single threads which is something like 1.5v. Which is made worse on the 5800X because of the concentration of heat on the 7nm die.
cheers dude. Was it only -15 through curve optimiser or did you have to change other things?
