Is my psu powerful enough?
I would get at least 650w for that, and you might want to edit out all those competitor names and prices because i dont think its allowed
600w is cutting it close .
Arctic P14 pwm are cheaper.
Why the 3700x over the 5600x ?
I'm feeling with the advice so far upping to 750w would be sensible and provide a bit of headroom as oppose to the zero currently available.
The 3700x was chosen due to budgeting. Finding a 5600x on the correct side of 200 was proving difficult!
Using Power Save profile in Radeon settings would be one way to make power draw more sensible per performance.
Already normal Vega 64 has bad enough power efficiency with no real advantage for that wasted extra power and heat.
So that model no doubt takes ineffiency up to 11 and half.
If your budget is that tight, you can't afford that heavily overpriced cooler either.
Neither can you afford such priced board.
And small M.2 is waste of limited slots.
Its not so much an issue or being able to afford but rather sticking to a target budget. Most parts were picked up second hand for a significant discount over retail prices.
I wouldn't worry, it probably won't hit 500W total power load, 3700x is quite a low power chip. I have a 3700x and a 1070 being powered by a 450W PSU, same brand as yours (Sf450).
For example my rig (see sig) pulls about 580W from the wall when gaming. I personally go with 850W as the price difference is negligible, and it gives you a bit of headroom...
I am running a 5800X with a 3080, on a Seasonic 650w SFX PSU.
Both parts are currently undervolted, but at stock settings… I still have no issues.
So you will be fine.
