Biggest problem for performance of GPUs integrated into CPU is memory bandwidth.
While for CPU low latency is higher priority, for GPU it's massive bandwidth because of massive number of parallel operations.
GPU would basically need some HBM in CPU package as faster cache.
Why would they bother when they can make a 6600XT which has a far smaller and less complex die that is 237mm2 vs the p5 @308mm2 and then sell the GPU for £450 and hopefully a CPU @£250+ to go with it.
APUs are fine if you want to get 30FPS at 1080p low settings.Why do they make low, mid and high end GPU's?
By your reasoning they really should just make one tier of either CPU's or GPU's..
It's about market share and in this current climate their APU's fill quite a big gap already!
My point was they are not going to make PC APUs as powerful as the 6600XT and then charge 250 quid while they can milk smaller easier to produce GPUs for almost twice the price.
The thread is namedBut nobody mentioned 6600XT's apart from you though..
The 6600XT is in most cases a max settings 1440p card while my initial query was for an APU that could actually handle 60fps at 1080p with medium settings.
Think GTX 1060 or RX580...
The thread is named
What limits AMD from creating a destop APU similar in say "1080p" performance to that of the PS5?
So the PS5 has 36CU's and is closer in performance to a 6600XT 32CU vs either GTX 1060 or RX580.
The 6600XT is not a 1440p and even AMD marketed it as a 1080p card, the ps5 will do 1080p 120hz and so will the 6600XT. The RX580 or GTX1060 will not do 1080 120hz + unless we are talking ancient games like CSGO.
It's still a confusing and poor choice of title since you're basically saying why can't AMD create an APU with the performance of a ps5 while then saying you actually mean an APU with the performance of a Ps4/ps4Pro.It was a basic question about an APU that does not require ultra low settings at 900p to achieve 30fps..
Also, I think you will find that the 6600XT is in fact far more of a 1440p card than you might think!
It's a 1080p card that can do some 1440p if your happy to lower settings or you just play older games.
But in theory it could be done, right?
