- 23 Dec 2020
Hey all, first off I want to apologize for my lack of general knowledge on hardware related issues, I'm relatively new to the pc gaming field. My problem is stuttering/framedrops/frametime spike issues, I'm running in 1440p 144hz and the framerate starts off good around 100+ like desired depending on what game I throw at it, but overall when something intensive happens (like someone throwing a fire bomb or two in Mordhau, or a big shootout in RDR2) the frames start to dip to and rise up but can't seem to keep it stable. roughly a half hour playing Mordhau gpu temps I have done the following
GPU core temp is around 77c, hot spot is 98c, cpu is 91c (Mordhau 1440p, stock amd cooler)
Disabled PBO (prebuilt manufacturers enabled it even though I had stock cooler)
Updated all drivers via AMD Auto detect
Made sure Ryzen Master was running on the default OC mode
Updated bios
Disabled XMP (and setting different memory times)
Increased DRAM voltage
Disabling Radeon Software Auto OC tuner
Disabled Freesync
Disabled Vsync
Disabled Enhanced Sync
Increased memory clock
Decreased core clock
Cleaning old drivers with the AMD cleanup utility
Disabled PCIE power saving
Disabled 10-bit pixel format
Disabled Microsoft game bar
Disabled discord overlay
Set audio channel to "stereo"
Increased the card's power limit via MSI Afterburner
Updated Ryzen Master
Set refresh rate to 60hz (from 144)
Set games to run at 1080p
Ran Crystaldisk, ssd came up as good
Ran memtest86 in usb bootup (no errors after 3 hours of runtime)
Last resort was a clean install of windows 10 and driver installs
Specs are:
Red Devil 6700xt
Ryzen 5 5600x (stock cooler)
Asus Prime b550m-a motherboard
High Power 650w 80+ bronze (not sure the exact model, couldn't budge the psu out enough to get a good look)
G Skill 2x16gb 2133mhz (XMP enabled to 3200mhz)
Powerspec clone of a Lian Li 205 (read not the best on thermals)
This is a prebuilt as I couldn't find a gpu and cracked when I saw the sale at MC, I'm feeling like I made the wrong purchase here.
Also as I'm pretty new to this forum is there anyway to upload an html I have a html of HWINFO if needed, thanks for your time.
Updated bios
Disabled Freesync
Disabled Vsync
Specs are:
Red Devil 6700xt
