- 16 Jun 2010
- Manchester
I have emailed you @haaammitThis server will need a Java client to join![]()
if you could give me a heads up please.
And replied - hope it helps
Allo - yes it's basically minecraft but with other players. You can do as much or as little as you want, build your own stuff but there's other stuff to see and do as well!hi, I am fairly new to Minecraft and I would like to play with others. Is this server of yours similar to the normal game, where you mine and craft stuff and make your own house and land but still interacting with others?
Just stick up your ign and I can add you to the whitelist, then you can hop on whenever you wantHow do I join if I can
Allo - yes it is still running, and yes, currently on 1.19.3Is this still running? Hopefully on 1.19.3?
