When are you going fully electric?
1 Mar 2010
yep - there's a list of tesla speed sign caveats, which I thought included max signs on the back of lorries V
extensive thread on speed recognition
https://teslamotorsclub.com/tmc/thr...ee-speed-limit-sign-recognition.151979/page-4
Does list a lot of caveats for the tesla system which may apply to Audi/BMW too, like contradictory speed signs ie roadworks requiring user to determine appropriate one, or,
camera can't see the sign because it's raining ...I suppose that was obvious ..."Sorry officer the car didn't see the sign"
7 Mar 2017
Glasgow
I wish we had solar, unfortunately living on the side of a mountain we don't actually get that much sun.
That's one point to the pod point though, Which power rating did you go for may I ask?
If you've not yet ordered I can recommend the Hypervolt charge point.
Its reasonably priced and has the best in the game customer services. We had one installed last week when our car came. All single phase car points will provide 7kW through their type 2 connector.
19 Oct 2002
Shakespeare’s County
Podpoint is sensible. Tethered works well as the disc wraps it up and the cable at 7.5m gives extra versatility. App now allows times charging control.
Like mentioned HyperVolt is new, good entry price and gathering a good amount of market share now.
Ohme doing a deal now with Octopus for £499 for the new Home Pro unit. Like the original Ohme (I have) it’s only 5m though.
4 Aug 2007
Wilds of suffolk
Ok
Interesting in the roughly 1100 miles I drove it never seemed to pick up anything as an issue apart from them specific signs, shows a picture of a lorry with 7.5T on it and the reduced limit along side it and contained within the same black box was the alternate limit, normally 40mph, which I assume is because thats not the standard limit for those vehicles on those roads.
22 Oct 2002
Near Cheltenham
It seems there are a lot of good chargers these days, we just went for the Hypervolt but could have easily gone with a zappi, ohme home pro etc, the Hypervolt just looked the right size and can wrap the cable around to keep that neatly tucked away. It’s due for installation on the 9th October and went for a 7.5m cable to allow guests to charge a bit easier.
Speed limit signs discussed above is one problem, near me we have side roads of a 40mph main road that have 20 signs at 45 degrees right at their entrances, these made the Model 3 I drove think the main road was a 20 instead of 40, but no idea how it could figure out that was for a side road, the council really need to turn those perpendicular. The newer speed limit signs could be just a software tweak though. The ID.3 max on older v2.1 has picked up 50 or even 30 signs on slip roads that are only 200 yards from the main carriageway, I’m sure that would be dialled out in a SW update.
Moving signs should be easy, the Tesla stuff is impressive and judging by the latest stuff in the ID.3 that also is fully aware of vehicles in a similar way as Tesla's, it will show you them on the dash just a bit more of a limited view than the very detailed/expansive field shown in the Model 3.
Man of Honour
13 Oct 2006
No idea what system it is but the speed limit alert on my parent's VW Touran seems way better than any of the newer systems I've experience of - it even picked up a temporary limit for roadworks that was being put up as we approached and never picked up the speed limited signs on large vehicles when I've been in the vehicle.
Not sure what it is running as new some features like lane assist were present but at the time disabled due to not being approved for use in the UK but enabled later via software update by the dealer.
4 Aug 2007
Wilds of suffolk
The car defoo doesnt pick up lorry limits (ie the stickers on the back) as speed limits.
I hadn't thought about it, but its quite possible the size of the sign is part of the equation. The lorry ones are small, so if the camera software requires an image between x and y in size then maybe the lorry ones are too small when they are in vision. Would make sense why they never seem to be picked up.
4 Aug 2007
Wilds of suffolk
The fact they are moving will also be considered. Often they cross reference with major roads and nav knowing the speed limit there anyway.
Good point, there are probably already enough protections to prevent the normal signs being misread, which would pretty much eliminate Mashers I would stick a 10mph sign on the back of my car nonsense.
The signs that were causing the issue I guess if they were standardised could be probably software fixed, if the formatting was formalised the software would need to check for a picture to the left as well. Doesnt sound hard to fix, I was just interested as it was new behaviour I had never seen, but equally I had never seen signs like that either.
1 Mar 2010
yes interesting point - teslas obviously renown for triaging, tracking, avoiding moving objects, versus temporary road furniture, predominately optically based too, with all the kit for FSD, so should be able to distinguish a moving sign,
Ford held the patent for sign recognition, so until that expired, manufacturers had to use databases - wasn't it
Would be interesting to know how Tesla lane keeping respond to static cars awaiting to emerge at junctions, or their etiquette for changing lanes to allow merging.
4 Dec 2002
Bourne, Lincs
Cheers for all the charger suggestions really appreciate it.
I'll have a gander at them all and report back with what we chose, Thanks again.
Hypervolt have a really good facebook group, the CEO is on there at all times of the day answering questions and commenting, their customer service is amazing, one of the reasons I am going with Hypervolt
Caporegime
20 Jan 2005
Co Durham
Cant find that deal only the £199 charging lead, got a link pleasE?
1 Mar 2010
19 Oct 2002
Quite an announcement from Osprey and the emergence of dedicated charging hubs rather the pop up single chargers in pub car parks model they had been operating.
https://ospreycharging.co.uk/osprey...0WmpIX1qTfharFChgz8RsjdwIqgUE1_e2b5PHqVpHyHAA
Kempower stuff too so tends to have a large array of power modules that feed charging posts to allow much better load balancing as the hub is fed power from the grid not each individual charger. Means the chargers you interact with are smaller too.
EDIT: Decent video here
16 Aug 2004
New Jersey, USA
Collected an ID.4 Pro S yesterday - the BMW i3 I had ordered back in March is still sat at the port waiting for an amplifier so I abandoned and managed to track down this ID.4 at a dealer in New York.
I was pleasantly surprised with it on the drive home, it's very quiet and the Travel Assist self driving is almost as good as BMW Driving Assistant Pro.
Quite a few software bugs though - on the drive home the microphone didn't work and I had to do a force reboot to kick it into life. Hopefully the OTA software update due soon will fix some of them...
The build quality is a bit suspect in a few places too, the piano black is going to get scratched so quickly.
