im not overly concerned about size. my monitor is 34 inches and set up on my coffee table. the joys of having a man cave
. if the speakers were too large for the table id put them on the floor or on stands.
I'm running Prodipe Pro 5 V3's, don't be put off by low price as there very good monitors.
To give a comparison on quality I've had both Edifier 2.0 and Edifier 2.1, and there are higher quality speakers. The Prodipes are entry level professional monitors, not consumer. Few things with them.
1) Response curve is pretty flat. Most budget monitors won't even print their response curve, Prodipe do.
2) There not to tiring when listening all day
3) Bi-Amp'ed and amps are good quality with plenty of reserve power.
4) Front ported so can be close to a wall.
5) Fiberglass woofers
6) Case is good construction, no vibration, front of cabinet has a separate front panel for strength. There is no unwanted vibration, or port noise, there is nothing to complain about on these monitors.
7) Balanced and unbalanced connections.
8) Prodipe sell an optional sub if you feel you need a sub in the future.
9) Very clean sound, I have enough resolution to pick up interference in actual recorded music tracks, I'm referring to the interference in the original studio recording.
10) No hum from the speakers, unlike has been reported on Yamaha monitors.
http://www.prodipe.co.uk/studio-monitors/2111-pro-5-v3.html
This is how they are on my stands.
https://photos.google.com/share/AF1...?key=ek1yeklfaGlOdXJjLWVWVXZwOHYzRkpZQkxld1VR
There are also Prodipe Pro 8 V3's that should be better, I'm actually considering updating to these next.
You will require a good DAC / soundcard as a source, as inputs are analogue only.
