Can you see it?
11 Oct 2006
Wiltshire
Please could you post if you can see the image below or not and what browser you're using? I'm pretty confident it'll be there in Firefox but others may not see it. Trying to find out why.
Oh, and is my sig visible?
Same here with Edge. If I try to add an image with Edge it doesn't show either. Yet I don't have this problem with Airgunforum which uses the same forum software. I'm starting to wonder if it's something to do with where the images are hosted so will experiment here with using my other ISP.
Host it over https and they will load.
Ah, thank you, that might well explain it. It may not be possible (or worth it) on PlusNet but I can move the folder I use for this sort of thing to my other domain on ICUK/CIX where I know I can get a certificate set up.
I don't know what causes it but it's been happening a while on here but I know images over https fixes it.
Browsers are getting fussier about accessing just http sites. It looks like Firefox is a bit more relaxed than Edge and Chrome but Safari is confused. ;)
Thanks for the help, everyone. I shall talk to my contact at CIX then start again.
Thanks for that. I can in Firefox too. I can see the image I've just added in Edge but not my sig images which is odd as they're in the same folder. Inspecting the code shows that the sig images are causing an overflow but they're the same images as before, just from another domain. The important thing is that the images are showing in the body of the post so I can do some selling.....
