*** New BitFenix Prodigy M 2022 + Alchemy Cables ***
3 Mar 2020
Introducing newest generation of BitFenix Prodigy M 2022 Chassis redefines chassis just like the original Prodigy. The compact and modern chassis with high quality tempered glass is suspended on Reinforce handles to showcase the components. With the support of up to top tier NVIDIA RTX 3090 series and AMD RX6900XT series GPUs or the Titanium ATX power supplies, the new Prodigy M 2022 efficiently supports large components with a smart layout design.The modular brackets allows the PSU and HDDs to be mounted on different locations clearing the way for support for up to 280mm radiator at the top and 120mm radiator in the rear. Pairing this up with the choice for either vertical or horizontal GPU mount and rich assortment of accessories, makes the new Prodigy M 2022 an ideal chassis for a variety of builds.
BitFenix Prodigy M 2022 Micro-ATX Case, Tempered Glass - black @ £85.99 inc VAT
Micro-ATX and Mini-ITX support, Tinted glass side panel, Mesh panels, preinstalled fans, ATX PSU compatible, carry handles, portable.
Only £85.99 inc VAT.
ORDER NOW
Also In White
BitFenix Prodigy M 2022 Micro-ATX Case, Tempered Glass - white @ £85.99 inc VAT
BitFenix Prodigy M 2022 ARGB Micro-ATX Case, Tempered Glass - black @ £104.99 inc VAT
Micro-ATX and Mini-ITX support, Tinted glass side panel, Mesh panels, Preinstalled ARGB fans, ATX PSU compatible, carry handles, portable.
Only £104.99 inc VAT.
ORDER NOW
Also In White
BitFenix Prodigy M 2022 ARGB Micro-ATX Case, Tempered Glass – white @ £104.99 inc VAT
Alchemy Cables
BitFenix Alchemy 3 x 8-pin PCIe extension 45 cm – sleeved white @ £44.99 inc VAT
[URL=https://www.overclockers.co.uk/BitFenix-Alchemy-3-x-8-pin-PCIe-extension-45-cm-sleeved-black-CM-35Y-BX.html] BitFenix Alchemy 3 x 8-pin PCIe extension 45 cm – sleeved black @ £44.99 inc VAT
https://www.overclockers.co.uk/BitF...-extension-45-cm-sleeved-black-CM-35Y-BX.html
[URL=https://www.overclockers.co.uk/BitFenix-Alchemy-4-pin-ATX12V-extension-cable-45cm-sleeved-black-CM-35Z-BX.html] BitFenix Alchemy 4-pin ATX12V extension cable, 45cm, sleeved – black @ £6.95 inc VAT
https://www.overclockers.co.uk/BitF...nsion-cable-45cm-sleeved-black-CM-35Z-BX.html
[URL=https://www.overclockers.co.uk/BitFenix-Alchemy-4-pin-ATX12V-extension-cable-45cm-sleeved-white-CM-360-BX.html] BitFenix Alchemy 4-pin ATX12V extension cable, 45cm – sleeved white @ £6.95 inc VAT
https://www.overclockers.co.uk/BitF...nsion-cable-45cm-sleeved-white-CM-360-BX.html
[URL=https://www.overclockers.co.uk/BitFenix-Alchemy-8-pin-EPS12V-extension-cable-45cm-sleeved-black-CM-361-BX.html] BitFenix Alchemy 8-pin EPS12V extension cable, 45cm – sleeved black @ £10.99 inc VAT
https://www.overclockers.co.uk/BitF...nsion-cable-45cm-sleeved-black-CM-361-BX.html
[URL=https://www.overclockers.co.uk/BitFenix-Alchemy-8-pin-EPS12V-extension-cable-45cm-sleeved-white-CM-362-BX.html] BitFenix Alchemy 8-pin EPS12V extension cable, 45cm – sleeved white @ £10.99 inc VAT
https://www.overclockers.co.uk/BitF...nsion-cable-45cm-sleeved-white-CM-362-BX.html
[URL=https://www.overclockers.co.uk/BitFenix-Alchemy-4-4-pin-EPS12V-extension-cable-45cm-sleeved-black-CM-363-BX.html] BitFenix Alchemy 4 + 4-pin EPS12V extension cable, 45cm, sleeved – black @ £10.99 inc VAT
https://www.overclockers.co.uk/BitF...nsion-cable-45cm-sleeved-black-CM-363-BX.html
[URL=https://www.overclockers.co.uk/BitFenix-Alchemy-4-4-pin-EPS12V-extension-cable-45cm-sleeved-white-CM-364-BX.html] BitFenix Alchemy 4 + 4-pin EPS12V extension cable, 45cm, sleeved – white @ £10.99 inc VAT
https://www.overclockers.co.uk/BitF...nsion-cable-45cm-sleeved-white-CM-364-BX.html
[URL=https://www.overclockers.co.uk/BitFenix-Alchemy-24-pin-ATX-extension-30cm-sleeved-black-CM-365-BX.html] BitFenix Alchemy 24-pin ATX extension 30cm, sleeved – black @ £17.99 inc VAT
https://www.overclockers.co.uk/BitF...X-extension-30cm-sleeved-black-CM-365-BX.html
[URL=https://www.overclockers.co.uk/BitFenix-Alchemy-24-pin-ATX-extension-30cm-sleeved-white-CM-366-BX.html] BitFenix Alchemy 24-pin ATX extension 30cm, sleeved – white @ £17.99 inc VAT
https://www.overclockers.co.uk/BitF...X-extension-30cm-sleeved-white-CM-366-BX.html
[URL=https://www.overclockers.co.uk/BitFenix-Alchemy-6-pin-PCIe-extension-cable-45cm-sleeved-black-CM-367-BX.html] BitFenix Alchemy 6-pin PCIe extension cable, 45cm, sleeved – black @ £10.99 inc VAT
https://www.overclockers.co.uk/BitF...nsion-cable-45cm-sleeved-black-CM-367-BX.html
[URL=https://www.overclockers.co.uk/BitFenix-Alchemy-6-pin-PCIe-extension-cable-45cm-sleeved-white-CM-368-BX.html] BitFenix Alchemy 6-pin PCIe extension cable, 45cm, sleeved – white @ £10.99 inc VAT
https://www.overclockers.co.uk/BitF...nsion-cable-45cm-sleeved-white-CM-368-BX.html
[URL=https://www.overclockers.co.uk/BitFenix-Alchemy-8-pin-PCIe-extension-cable-45cm-sleeved-black-CM-369-BX.html] BitFenix Alchemy 8-pin PCIe extension cable, 45cm – sleeved black @ £11.99 inc VAT
https://www.overclockers.co.uk/BitF...nsion-cable-45cm-sleeved-black-CM-369-BX.html
[URL=https://www.overclockers.co.uk/BitFenix-Alchemy-8-pin-PCIe-extension-cable-45cm-sleeved-white-CM-36A-BX.html] BitFenix Alchemy 8-pin PCIe extension cable, 45cm – sleeved white @ £11.99 inc VAT
https://www.overclockers.co.uk/BitF...nsion-cable-45cm-sleeved-white-CM-36A-BX.html
[URL=https://www.overclockers.co.uk/BitFenix-Alchemy-6-2-pin-PCIe-extension-cable-45cm-sleeved-black-CM-36B-BX.html] BitFenix Alchemy 6 + 2-pin PCIe extension cable, 45cm – sleeved black @ £10.99 inc VAT
https://www.overclockers.co.uk/BitF...nsion-cable-45cm-sleeved-black-CM-36B-BX.html
[URL=https://www.overclockers.co.uk/BitFenix-Alchemy-6-2-pin-PCIe-extension-cable-45cm-sleeved-white-CM-36C-BX.html] BitFenix Alchemy 6 + 2-pin PCIe extension cable, 45cm, sleeved – white @ £10.99 inc VAT
https://www.overclockers.co.uk/BitF...nsion-cable-45cm-sleeved-white-CM-36C-BX.htmlhttps://www.overclockers.co.uk/BitF...nsion-cable-45cm-sleeved-white-CM-36C-BX.html[/url][/url][/url][/url][/url][/url][/url][/url][/url][/url][/url][/url][/url][/url][/url]
Man of Honour
26 May 2012
Hopefully they're no longer using the god awful soft-touch coating on the plastic. Those get super sticky after a few years and the case basically needs to get thrown away. :(
22 May 2010
Minibotpc
What a weird fan to include, 60mm on the front. Blowing in general direction of top of motherboard.
Why?
That is weird... 60mm at the front what good is that gonna do?
Even says it could support upto 2 x 60mm or 1 x 120mm at the front. Surely it'd make more sense to include 2 x 120mm fans front and back.
10 Apr 2015
Hungerford, UK, Earth
I had the Phenom which i think shared the same chassis, you could fit 200mm in the floor, 2x120 top and 1x120 rear. but it was very very cramped in there. the ITX version were easy to build in the motherboard was horizontal
I dont belive there were every any fans in the front due to the PSU, and at the top the older version had a 5.25" bay
