AORUS GEFORCE RTX 3080 MASTER Support Bracket/Anti Sag
Tewerfitisme do an RBG anti-sag bracket with a screen on it. Other than that the CM ELV8 Stanners mentioned or the UPHERE ARGB bracket would work.
@philo-sofa Don't suppose you have a link for the one you recommended as can not seem to find it thanks.
Ignore i have found it.....the UP Here ARGB he has from his old card will not fit as the card itself is too high when installed the height of it is across the fans and there is no way to support it.
Link to pictures of card.
https://bit.ly/3kS6H83
Apparently this does not fit the Aorus 3080 master according reviews on on this gutted.
Reviewed in the United Kingdom on 29 December 2020
Didn’t fit with my aorus 3080 master
Has anyone tried to fit this bracket with a Aorus Master 3080?
