cant close the glass side on my lian li o11 air
9 Nov 2020
i recently got the lian li 011 air case, the problem is my gpu power leads stop me from beiing able to close the glase side completely, anyone got any ideas on how to sort this?
You can get low profile right angle / 180 degree PCIe connectors that you could plug into the card and connect the cables to. This would probably cut down on the space usage significantly.
