- 13 Jun 2016
- UK
This is a new thread to avoid completely hijacking https://forums.overclockers.co.uk/threads/when-does-an-old-smartphone-become-unsafe-to-use.18938254
Thanks @BigBoy - I believe I have done it that way, but clearly I am not getting something right.
I am using Lineage OS 18.1, having found the file I downloaded from Lineage's website, it's "lineage-18.1-20210921-nightly-walleye-signed.zip". I've also tried these versions of GApps:
Thanks
Flash the GAPPS https://opengapps.org/ package for your device and you will have full Google integration (maps playstore accounts and so on)
Thanks - I did try that, as well as MindTheGapps. Whenever I tried flashing with opengapps, it failed saying that the version of Android was incorrect for that version of OpenGapps. When I tried flashing with MindTheGapps, it seemed to work, so I rebooted from TWRP recovery into Lineage OS - and no Google at all.
I've tried the core and basic MindTheGapps, as well as the Pico, Nano and Stock of OpenGapps. None of them seem to actually do anything and I am installing them immediately after installing Lineage OS and before booting into Lineage OS for the first time. To be honest I am not overly bothered, but equally if I could work it out it would be nice to know what I did wrong, if anything!![]()
What version number of Lineage are you installing? When on the open GAPPS page you need to select arm64 android11 and micro and flash that package.
I've always done a full wipe (Dalvic and system partitions) then flash the OS package and GAPPS straight after.
Dirty flashing (flashing without clearing cache system partitions) is to be avoided at all costs!
- open_gapps-arm64-11.0-pico-20210928.zip
- open_gapps-arm64-11.0-nano-20210928.zip
- MindTheGapps-11.0.0-arm64-20210920_084011.zip
- NikGapps-core-arm64-11-20210918-signed.zip
- NikGapps-basic-arm64-11-20210918-signed.zip
Thanks
