but people such as yourself were arguing that IPC would no longer matter and hence Bulldozer's poor IPC wasn't important, AMD fans used to post high resolution gaming benchmarks where there was an obvious GPU bottleneck and use that as evidence.
For gaming a high IPC processor with fewer cores will nearly always beat a high core count chip with poor IPC, game engines are not well suited to parallel processing.
It's true that you need the right balance but to use extremes as an example you'd get way better performance in games from a single core 4ghz chip versus 4 cores at 1ghz, adding more cores should be supplementary not done at the expense of IPC like it was with Bulldozer.
