I think my desktop doesn't have secure boot/tpm?
I'm not actually sure.
I'm not fussed if I can't upgrade. Win 10 is fine.
But I won't be updating my surface book if I can't update my desktop
Do you know what CPU/motherboard you have?
It's under a fiver to buy a license for the app after the trial ends, worth it IMO given the features!I might have to have a play with that as there are a few features I preferred in 10!
So I can't download Windows 11. On windows update screen its saying:
"This PC doesn't currently meet all the system requirements for Windows 11".
It then directs me to download the PC Health Check. The PC Health Check says "This PC meets Windows 11 requirements".
Not sure what to do? I have TPM enable too. Any ideas?
They will probably work, its not that different.
Why do I get this silly message ?
Download the health check app and it'll tell you why, i.e TPM or secure boot not enabled.
Just installed StartIsBack and am very happy to have a nice taskbar, context menus and start menu back and customised how I like!
https://www.startallback.com/
And I found some old desktop screens from 2010, how things have moved since then lol.
Same as me.
Same here, I looked on Reddit and loads of people are reporting the same issues!I just enabled those in BIOS. No luck.
In the healthcheck app it does say I can get W11. But in Windows it says I can't
Same as me.
I did not either. Just go grab the media creation tool. Use an USB to install it on and upgrade or clean install from there.Strange, I dont see the update option for W11 in my settings?
Do you get the options to get the quick launch section back and to remove the W11 version (icons in the middle)?Just installed StartIsBack and am very happy to have a nice taskbar, context menus and start menu back and customised how I like!
