GPU manufacturers pros and Cons
OP
12 Apr 2020
The rank ordering in my head:
Green Team
1. ASUS and MSI
2. AORUS
3. EVGA
4. Non-AORUS Gigabyte
5. PNY and Palit
6. Zotac
7. Inno3D
Red Team
1. ASUS and MSI
2. XFX
3. Sapphire
4. Gigabyte and Powercolor
5. ASROCK
It's more complex than a simple manufacturer average though. e.g. both PNY and Zotac make some great cards (HOF and Holo Black respectively) while ASUS and MSI both make a weak card (Dual and Ventus 3X respectively).
Thanks for sharing your list. One of the main concerns for me is thermal performance. I’ve seen a few videos of people replacing thermal pads and at first glance they don’t look particularly thermally efficient judging by the thermals after pad replacement. I’d rather not have to do that.
22 Oct 2012
Thanks :) Although it was luck of the draw, being concerned about memory temps am glad I happened to get the TUF. Both their AMD and Nvidia cards connect the memory ICs directly to heatpipes and on to radiators. The thermal pads tear if you remove the heatsinks (which afaik is common) but otherwise appear solid.
In practice my 3080 memory can hit 98c, not bad but aftermarket pads would probably lower that substantially.
11 Jun 2021
Earth
MSI are usually my brand of choice, I think they hooked me with twin frozr II on the 6870, never had thermal/quality issues with any of the cards I've had since.
Current situation is grab what you can when there is a deal / offer on. Or try for an FE drop.. don't buy at shelf prices.
OP
12 Apr 2020
Yes it is a bit of a lottery atm. I’m trying to line up for an FE card. Does anyone know when they are?
Caporegime
21 Jun 2006
Green Team
1. Founders Edition
2. Palit, ASUS and MSI
3. Gigabyte
4. EVGA
5. PNY
6. Zotac
7. Inno3D
Just make sure you upgrade warranty on the EVGA's and register Gigabyte ASAP to get their longer warranty cover. Asus also allow you to upgrade warranty.
16 Jan 2010
Earth
Warranty period is the most important attribute, Zotac Nvidia and Sapphire is my preferred AMD partner. Never XFX as they cheap out on important components
to rip off their customers and nerf their cards.
21 Apr 2007
Warranty is increasingly important as the replacement cost and unavailability of GPUs has risen so much in the past 5years.
I would immediately exclude anything less than 3yrs and never buy anything (computer related) 2nd hand above £500.
16 Jan 2010
Earth
The consensus from you ladies seems to be that I'm desperately wrong :) Go on @Aretak @Gerard, I'm happy to be corrected. What would you put where?
For what it's worth while I'm more certain about Nvidia cards I'd suggest I'm about right for current AMD GPUs. ASUS have excellent cooling at least, am less sure about the PCB itself, similarly the current XFX line-up reviews damn well.
XFX might be vaguely OK for AMD but I have severe trust issues since my 4870 (iirc it was that model) from them turned out to have gimped memory. That saved XFX a couple of dollars and left me with sub par performance, never again XFX.
16 Jan 2010
Earth
You need to get a telegram or discord Nvidia parts alert which you need to respond to immediately you're informed they're in stock. There's something about it on the 3080 FE thread I think but you'll have to look as I haven't.
OP
12 Apr 2020
I’ve heard of discord. What is telegram?
