Caporegime
- 9 Nov 2009
- Planet Earth
OP just stick with what you have. Many enthusiasts like upgrading every 5 seconds, and with CPUs, it's a big difference if you are buying a £100 to £150 cpu every few years but not when you are spending £240+ all the time. If you are spending £250 on a Ryzen 5 5600X, a Ryzen 7 5800x at £340 is almost the same price per core and has higher clockspeeds.If that Ryzen 7 lasts you three years instead of two years with a Ryzen 5 5600X, the latter is not really cheaper. Plus the Ryzen 7 will have a higher resale value.
Plus in many games with RT, your RTX2070 is going to run out of steam quicker at 1440p than the CPU. It's all fine and dandy showing an RTX3090 with resolution scaling at 720p but from my own experience my RTX3060TI ran out of steam at 1440p with RT on well before the CPU.
On top of this in CB2077 I found the RT reflections the most noticeable effect anyway.
