X570 will support 2000 series onwards although some will unofficially support 1000. 5000 support may require bios flashing.Hi,
With the AM4 slot running with a motherboard such as a 570 chipset. What generation Ryzen cpu that can be used with it. I appreciate you ideally want to be using the latest generation 5000 series but how old could you go?
Why would you want the latest motherboard and an unsupported cpu ?I’m interested about the unofficial support. I guess that’s a take your chance unless a manufacturer tells you otherwise for a specific board.
I haven't checked, but it's probably not listed on the CPU support pages of any motherboard, because AMD don't permit these combinations. You can google the board model and the CPU and it should come up if somebody has used it. Compatibility may also depend on BIOS version, so be careful.I’m interested about the unofficial support. I guess that’s a take your chance unless a manufacturer tells you otherwise for a specific board.
I think I’ll stick to the officially supported versions. I’m not sure I have the patience or time to go off piste.I haven't checked, but it's probably not listed on the CPU support pages of any motherboard, because AMD don't permit these combinations. You can google the board model and the CPU and it should come up if somebody has used it. Compatibility may also depend on BIOS version, so be careful.
