- 2 Feb 2020
- UK
Hey,
I need to replace the filler valve and need the cistern off the wall as far as I can tell. The water inlet nut is in a really hard access area and I can't get an adjustable wrench on it. Then there is the plastic one hidden further behind that.
Are there any magic spanners or tools for these things? I have no idea how I'm going to loosen both of those?
Thanks for any help!
Is this flexi connection onto the copper pipe 'reusable'? Or am I going to damage the seal/olive on the compression fitting if I remove and then refit it?
