Has anyone calculated what impact this would have on bills? Unsure if I would bother, depends how far energy costs spiral. Just working 9-5 on windows desktop doesnt use much GPU grunt/power.
I think he means after cooking rather than just warming up the room with the oven. I do the same if we've used the oven - once the food is cooked i leave the door open to let the hot air out to warm up the room. It doesn't last long, but can easily take the chill off the room. Same applies with the dishwasher when it's finished.
So how many times a day do you use the oven in your house for cooking ? We only use it at tea time so wouldnt keep us very warm. I think you need to wake up and smell the coffee.
p.s clean ovens dont smell.![]()
Quick rule of thumb for you: @20p /kwh 100 Watts on all day, 24 hours is nearly £0.5.
Rule of thumb 2: How much cheaper is a gas fire at heating a room than a computer? Assuming a slightly older non-glass fronted, its between 3 and 4 times cheaper than the computer is.
Buy a games console.![]()
People have other bills too.People are honestly worried about 7.5p per hour of gaming?
A monitor pulls 50w or so. An average GPU pulls 200w and an average cpu 65w.
If you have stupidly specced a 16 core CPU for gaming then that is on you.
I'm using a 5600x, 3080ti and a 32 inch Samsung odyssey G7. It will cost me around 7.5p per hour of gaming.
That means if I game for 10 hours per day which I don't it's 75p per day.
I literally spend more on soda water per day to drink. It's buttons the cost to run a gaming rig.
At some point all those "buttons" add up.
If you saved 25p a day by make a small change it can go towards other bills or towards your soda water.
The whole point of the thread was that prices are going up.
I'm not going to change my gaming habits to save 15p per day. It's pointless.
You would literally be better off changing something else not your gaming.
For instance get rid of your tumble dryer that will make more savings than stopping gaming.
 Which is also another variable. Age of house (ours is nearly 30 years old). yea, that is the main waste. Systems powered on and idling doing not much useful.having multiple systems, monitors etc powered on
Depends on how you look at it.A computer is very inefficient at of heating a room compared to a radiant heater, gas heater or heat pump
