Anyone into Gundam (or Gunpla)
Caporegime
20 Oct 2002
Wish i was in a Ramen Shop Counter
Anyone here into Gundam model building?
I built an SD one as a kid but that was decades ago, in order to relive my youth :D I have just jumped back in, with both feet and order a PG RX-78-2 Unleashed.
Not going to go all the way with spray paint as the plastic are already colour coded in all the right parts. What I am trying to do is doing minor things like Panel Lining, bought a set of 3rd party water decal (£250 kit and it didn't come with it….stickers are just naff IMO).
If anyone is into it, show us what you've built!
Things I already have on order besides the kit.
A SD Gundam RX-78-2 as a trial one.
A Pair of Godhand
Dspiae Sanding sponge set (180 to 800)
Tweezers
Swann Morton scalpel
Mr Mark Setter/Softer
Brushes
Tamiya Panel Accent Liner in Black, Grey and Brown.
Enamel Thinner
Paint cleaner for brushes
I will also post progress as I build it, hopefully I won't embarrass myself lol
Following this for updates, I've seen a few Gundam mod videos on youtube and they always look phenomenal!
Haven't got the funds or the time to do it myself along with all my other ongoing projects but fair play to anyone who has.
Gundam arrived today!
Built quite a few when I was younger, unfortunately they're all at my parent's as I'm too scared to move them due to how fragile some of them are and I don't have a proper space to display them in my current place. I never really tried modding back then since I was young and didn't have the skills but I do plan to get back into it one day and try at least panel lining.
Good luck on the PG model! I had a PG OO-Raiser and it took a fair chunk of time to build. Can't wait to see the final result.
Yup use to buy a ton of these whenever i visited family in HK. Don't even know how much money i spent, still have a few but they're in pieces and covered in dust.
Should really clean them up and put them back up on display.
I'll one day want to build a perfect grade but just don't have the time for it right now.
Great looking model!
Was thinking of getting something like that for my brother for Christmas, but £200+ is a bit out of my price range. :(
Can you recommend any models, or a model range to look at?
I'm looking around £50-£60.
There are so many and honestly i don't know enough to recommend them, what you are looking for if you do a search is "Best Master Grade Gundam" which should narrow it down. Generally speaking, the newer released versions are better than older pre 2000 designed. Some have LED inside them, some don't. One you found the one you like the look of, search for a review of it.
If it is the original design that you are looking for, by original as in the one i got, the RX-78-2, then they make a 1/100th scale of the same one too. £60, right in your budget. Make sure you get Version 3.0.
https://www.amazon.co.uk/Bandai-Hob...ocphy=1006790&hvtargid=pla-505176743517&psc=1
Dayum you went all in on your first model.
Last kit I built was a MG Freedom 2.0, was my first fully panel lined and decals with a top coat. Just find them too expensive to buy over here. I would get a new kit every time I went to HK as a kid. They would be dirt cheap from a dodgy stall in a dodgy shopping mall.
Gundam kits are everywhere in HK, I remember seeing walls of it in Toys R Us. I used to ignore them because partly because the boxes are too large to take home, also I wasn't into making models for the past 20 years. I really liked it when I was a kid living there.
Thanks for the invite here Raymond.
Hobbylink Japan would be my go to site for Gundams. https://www.hlj.com/gundam little warning that you might need to pay customs (sometimes).
I used to build these when I was younger but picked up on them again since lockdown last year and needing something to do apart from gaming!
I am used to buying things from Japan so custom side of things is not a problem. I normally buy from AmiAmi and Mandarake for my figures. The problem with them isn't so much the list price but the shipping cost because Gundam boxes are quite large and it can cost £50+ to ship by air easy. It's done more on size rather than weight.
What's shipping cost like with Hobbylink Japan?
They give you a good range from slow to fast shipping, similar to your sites HLJ also varies depending on weight/size of your package. For example 1/100 scale Gundam, they'll usually ship it for around £15 to £20ish on the slow boat.
I picked up a few over the last few months, really like the MG range. I'm on the hunt for a PG but unsure what one to get, although i should build the Titanium Sinanju first.
Huh, reminds me that I do have the MG Strike Freedom kit I haven't built yet sitting in storage. I should probably get around to building that.
