any TV recommendations for under 1k? samsung or something usually good for gaming right?
If you're not a size queen then you can get the 48" LG CX (OLED) for under 1k now. 55 is £1100 most places.
Fwiw I've started adding them all even if I'm not interested, incase I change my kind or the kids want to try it at a later date.The way it works.
Every month some games get made available, they are not automatically added to your account, you have to manually activate them. Once activated they are available to play for the life of the account, provided you have an active PS+ subscription. If you unsubscribe, and then resubscribe they are still there, but you can only play when the subscription is active.
Did you literally post that same sentence on HUKD?When I add it to the basket, it is adding a hefty import duty, so it is acutely £145 including import duty. Thanks Brexit!
No! wasnt me.Did you literally post that same sentence on HUKD?
I don't work for the store, I'm here to ensure you follow the rules that you agreed to when you signed up. Simple.Price match them. Simple.
My apologies, I should have checked to see if OCUK sold the same drive, though does it really count as a competitor if you're pricing it 46% higherGuys remember where you’re posting and the competitor rules please.
?You don't need to cancel the sun. If you buy a 12 month sub and apply it. It will stop the monthly payment.
Any word on 1440p support for the PS5 ?
They do yes. Typically though it just brings it down to about the same price you can get it through cards anyway.Can anyone recall if Sony do Black Friday/Cyber Monday deals for PS Now and PS Plus? I'm thinking of subbing to PS Now again but would be nice to get it cheaper, of course.![]()
Probably due to not enough demand ?Yeah the lack of 1440p is the only thing that would drive me to Xbox. It’s pretty poor tbh, needs sorting.
You’ll be fine. I’ve got a fair few installed atm.How bad is it just having 500gb on these consoles. I don't get much gaming time so I usually play one or two games at a time, will that be fine or do I seriously need to look into investing into more storage?
It's 600+ though can't remember the exact amount. Not a problem for me as I never need more than 3 at a time generally.How bad is it just having 500gb on these consoles. I don't get much gaming time so I usually play one or two games at a time, will that be fine or do I seriously need to look into investing into more storage?
