 - 13 Oct 2021
 - England
Dear Forum,
I have a house router and a studio router with studio being 100m down the garden. Both routers on same SSID, differeing IPs [192.168.1.254/252], House is Smart Hub 2, Studio is Home Hub 4 no DCHP, old Netgear Switch GS108 and Draka Patches
im no expert in this field but thought i knew enough to set this up. Some things work perfectly, others dont. Those that dont work seems sporadic
When things dont work, the item gives itself an IPv4 address ok in the house/router 1, but when moving to Studio/Router 2, it sometimes gives itself an IPv6 address and then doesnt connect to network.
The studio feed doesnt go through Patches but does go through Switch.
ive just moved in so the BT Smart Hub was supplied to me, and i had a Home Hub 4 lyijng around so used this for Studio Router. Should i use 2 similar products? a Friend has advise 2 of these:
*** no competitor linking ***
is something hinding my network to the Studio? Grateful for advice
