...or so it would seem from her 6 year old Clio's MOT failure.
Do not drive until repaired (dangerous defects):
Anyone else out there with a decent sized MOT bill......
- Nearside Front Tyre has ply or cords exposed (5.2.3 (d) (ii))
- Nearside Front Coil spring fractured or broken (5.3.1 (b) (i))
- Offside Front Coil spring fractured or broken (5.3.1 (b) (i))
- Nearside Front Macpherson strut damaged and seriously weakened top mount (5.3.3 (b) (i))
- Offside Front Macpherson strut damaged and seriously weakened top mount (5.3.3 (b) (i))
- Nearside Front Suspension arm ball joint excessively worn (5.3.4 (a) (i))
- Offside Front Suspension arm ball joint excessively worn (5.3.4 (a) (i))
- Nearside Front Windscreen washer provides insufficient washer liquid (3.5 (a))
- Windscreen wiper does not clear the windscreen effectively both front (3.4 (b) (ii))
- Front Lower bottom of bumper/undertray insecure (snapped around bolts)
- Offside Front Tyre worn close to legal limit/worn on edge (5.2.3 (e))
- Offside Front Brake pipe corroded, covered in grease or other material (1.1.11 (c))
- Offside Front Suspension arm pin or bush worn but not resulting in excessive movement rear bush (5.3.4 (a) (i))
- Front Registration plate insecure but not likely to fall off (0.1 (a))
