Do you still disconnect other drives when installing windows?
21 Dec 2019
Planet Thanet
no dont see why you lot take extra steps to disconnect drives. this has not been needed since xp..
1. Have your OS drive be a different total size than all others.
2. when installing windows
you will see:
drive 0: 250GB
drive 1: 1TB
drive 2: 1TB
just use your eyes job done... not exactly rocket science
It's mainly done to avoid boot record issues
Example 1 drive fails and your pc wont boot because it's looking for that drive
Had that happen plenty times as can't simply
Turn off nvme drives as mentioned
Not because of formatting the wrong drive during setup
Though no doubt there's been people do that too
21 Dec 2019
Planet Thanet
You only format the wrong drive once (in the DOS days for me).
But yes, on my motherboard at least you can disable individual ports, so I just do that these days, not that I reinstall Windows often anymore anyway.
Individual nvme m2 ports?
Sata ports usually you can but not had a motherboard
I can do nvme m2 ports
If yours allows those that would be useful
9 Dec 2006
@ManCave
Boot record issues was fixed like 5 years ago.
It was an issue in windows 7 but never an issue with W10.
as long remove all the partitions so only 1 item for
Drive 0:
Remains then boot record will be created on the right drive.. drive 0.
If you don't clear up the extra partitions before install/reinstall then it will use other drives for boot records
So as an ex MVP this feature is working as intended, just seems no one understands how it works..
Either way you do not need to disconnect drives anymore.
21 Dec 2019
Planet Thanet
Drive 0:
Not sure if it's because I have multiple drives with windows installed
Not just 1 and the others as data/storage
But still seems to be an issue for me :(
18 Mar 2006
Birmingham, UK
Ever since I got the TLDR missing error after a secondary drive failure I always have installed with just the install drive. I know its not required any more but you built habits.
25 Jan 2007
King's Lynn
Yes, still do due to the way I have my drives setup, user folders/documents etc are on a different drive to the OS/programs.
Once windows is installed I just 'reattach' the relevant user folders to the other drive.
Might be a little different when I upgrade and get nvme etc but for now with good old sata based drives I'm sticking with what works lol
16 Aug 2009
I disable the drives in the bios, Windows can still have a werid habit putting the bootloader which isn't the primary drive.
I unplug them its a simple click the release on the SATA cable. Removes any possibility of anything going wrong and sometimes the installers options can be confusing. Backup drives data is too important to risk!
21 Dec 2019
Planet Thanet
So yeah my memory wasn't wrong for a change
Even with windows 10 or 11
It's still possible to make your boot record wonky
If don't disconnect drives
Just to make it clear I have multiple drives with windows installed
Not just one and the rest are storage
Did it to myself yesterday
Installed Windows 11 new preview
Totally cleared the partitions as mentioned earlier on target drive
Ended up missing 1 drive/operating system
Luckily it was simple enough to add the entry
Using easybcd
So maybe I am doing it wrong or maybe not
But it's definitely a possibility it can happen
9 Dec 2006
@ManCave
most people dont have multiple windows targets on 1 pc ;)
to fix that you would have the remove partitions from both disks then reinstall the bot manager separately on both drives so they are locked to their target partitions
5 Dec 2002
The 80's
You could use diskpart to clean the disk you want to use before installing. Disk should then show up as a unpartitioned in the disk selection on the installation wizard.
