- 21 Dec 2019
- Planet Thanet
There's a few things you need
Microsoft account
64gb or higher usb drive the faster the better
Rufus
Windows 11 iso
You can now make a live usb to test windows 11
Without having to install it
It also works as windows to go so you can take it and
Use it on other PC
Handy for using at a friend's house etc
It's a persistent live usb
So you can install software, updates etc and they will remain after reboot
It also should avoid compatibility checks so can test
Even if your pc doesn't meet requirements for Windows 11, TPM etc
Simply select windows to go in Rufus drop down menu options
It will even fetch the windows 11 iso for you if you want
Also useful for troubleshooting,data recovery etc
Especially if you're not used to Linux you can have a familiar environment
To try to test or fix stuff instead of trying to work with a
Linux live usb
Played around with it earlier
And it's actually pretty good especially if got a fast usb drive
The first time you connect to a device you need to verify it by emailed code
From your Microsoft account
But after that you don't need to verify
Microsoft account
Rufus
Windows 11 iso
Use it on other PC
Linux live usb
