Caporegime
I've sat on Argos website since 8am and not a sausage! It's never been in stock in any stores near me. I did pick Sheffield just as a random location to try and there were some there.
That does look quite smart, definitely quite thinning.
For reference the plates are "benazcap plates" from the forest.Appreciate you doing that. I think it's time I black the plates, wasn't happy with the finish using plasticote spray.
The WD SN850 seems like a good option.Managed to get a hold of a PS5. Should be here next week.
What's a good SSD to grab for it?
WD SN850 with a QIVYNSRY M.2 Heatsink from the forest.Managed to get a hold of a PS5. Should be here next week.
Does anyone get Lan Cable disconnected then connected instantly after? Its causing me a headache
Enjoying my ps5 the last few weeks I've had it, just one problem, I keep getting the LAN cable Disconnected/connected notification, its ******* annoying, do I have to manually set something in network connections to remedy this?
I'll have a look when I get it later, it's the virgin hub 3 so prob due an upgradeIs your router somehow assigning dynamic local IP to anything that switches on/off?
