- 17 Apr 2006
- Hampshire
Yes, although now that you've quoted me I feel I should clarify that it should be at the worst case, i.e. if the cooling control can keep below throttle when there is maximum load on CPU and GPU and with the highest ambient temperature that you should expect, then what the water temperature actually is doesn't matter.
Great - thank you for clarifying.
What solution did you use for your PSU out of interest. The PSU fan is the final thing in my setup that isn't very quiet
