- 6 Jan 2013
- Rollergirl
The voice/speech recognition is astounding
In what way, how have you tested it?
Just looked at the specs for the 20x...wow! It's pretty much a full centimetre longer and wider than the P6P!
I'm using my 5ii at the moment as my P6P is charging...16.6mm narrower, it must feel huge! (That's what she said)
Just to send messages, having a Scots accent I've never had much success with any devices, this seems markedly different.In what way, how have you tested it?
Download APK online and continue using Evie..Mine arrived on Friday. Coming from a pixel 5 which I've been using completely unaware that evie launcher has been binned so it looks like I'm needing to find another suitable launcher. Currently trying Niagara but meh, I don't like paying for simple features.
Any good recommendations? Similar to Evie?
Standard pixel 6 arrived back of 2 and i have been messing about with it since. First pixel phone and gesture control taking a bit of getting used to, tried installing Nova but couldn't get the three buttons to appear at bottom of screen. Had bought a spigen case and spigen tempered glass screen protector.
Case fits really well, so does the protector but it totally ruins the fingerprint reader. Will give it a couple of days to see which protector i go for next.
Took 2hrs to sort out.Oh I've been there, they screwed up my transfer when I tried it on another phone. I still look at the chat log when I need a giggle.
System>gestures>press and hold down power buttonAny ideas on how to get the power button to to launching the assistant?
Thank you.System>gestures>press and hold down power button
I do see what they mean about the fingerprint reader though, it is accurate but you have to keep a finger on the screen for a split second for it to register.
Testing it side by side with Samsung Note 10, it seems slower as with the Samsung I can just about tap the reader to unlock whereas here you have to hold your finger. It isn't actually slower to unlock but feels like it due to having to hold the finger. Accurate so far though but have to slightly adjust how you use it.
