I'm thinking about turning to the dark side and watercooling my next build. But while I've read a lot, I've never actually done it. I've yet to decide whether to go for Ryzen 59xx, Threadripper 3945 or 55, or Intel 12xxx.
I'm not particularly interested in overclocking, just running cool and quiet.
For the bits, I really like the look of the Fractal Torrent, so I'll be going with that. So I'll need a 360x180mm radiator. Will I need an extra set of fans for a push+pull arrangement? I'll need a pump and reservoir - which one? - and front and back blocks for my 3090. I'll need a CPU block. A drain port. Tube fittings, including 45 degree and 90 degree fittings. I may need pass-through parts (see below). I'll start with soft tubing. Have I missed off anything?
It would be nice to have an intelligent CPU block: one that displays the flow rate, the temperature, and so on. Better still if it reports it to the computer too.
How about tools? I'll need a fill bottle, a cutter, something to shape the tubing, and a pressure tester. Anything else?
One thing I will want to do if I go the watercooling route is to hide the tubing as much as possible. I don't mind drilling holes, but my first thought there is to route the tubes from the CPU and GPU to the rear of the case then down above the slots and along the bottom. Would it be useful to have quick disconnect joints there? The reservoir will have the entry and exit ports at the bottom. I'll use cable ties to clamp them together neatly. Unless you have better suggestions!
Roughly how much will this cost? Are my thoughts correct? I think it's going to be well over £500, probably near £1000, but the only parts that will not be reusable will be the GPU blocks.
This is a research thread; I'm probably not going to act on it for some time.
