Dry Ice Cleaning / Restoration
28 Sep 2008
Britain
Has anyone experience of dry ice cleaning / restoration? The results are amazing. Looking to see if it's something I can get done, or better yet, grab a machine myself, perhaps as hire.
Caporegime
23 Dec 2011
Northern England
I worry about it a bit. In a lot of the vids all they're stripping off is the protective wax coating applied by manufacturers.if you're going to recoat then sure, go for it, be very wary around your paint though.
OP
28 Sep 2008
Britain
it's the Karcher vid that's got my attention here:
https://www.kaercher.com/uk/professional/dry-ice-cleaning.html
and I've discovered my local oven cleaning specialist has invested in one of these too. The results on ovens look amazing
Caporegime
23 Dec 2011
Northern England
1 Jun 2014
ObsessedGarage on youtoob did a fair bit about it recently, granted he's based in the US but could give you more insight into the uses.
Caporegime
24 Oct 2012
Godalming
It's literally a mild sandblasting alternative, it even says in the vid "efficient removal of underbody coating" - ie, it strips whatever's on the surface but uses dry ice particles rather than media / sand / whatever this year's fashion is. Use it if you intend to treat the surface afterwards, but there's zero chance I'd be using it on a painted car which I'm not restoring.
OP
28 Sep 2008
Britain
ok, so to be clear, the complete opposite of what they've used it for in the M5 resto video? Gotcha :D
