nvflash won't let me flash my old bios back under any circumstances. Is the card shot?
3 Nov 2021
Serbia
So i flashed a bad bios to my gtx560 ti. And it displayed some weird white stuff.
That was ok, i thought i could just flash it back, right?
Well no, it turns out i can't flash ANY, even the backed up original bios. I have tried millions of nvflash versions, even the supposedly bypassed ones, which throw out the same error. Why does that happen, shouldn't they be made NOT to do that?
I have no idea what to do anymore. I've tried everything that the other people who faced this error did, and none of that worked for me. Do i have to resort to the physical bios programmers, or is the card completely gone? I even tried the DOS nvflash and that won't even start. Is there something else i can do when its comes to windows flashing or?
9 Dec 2006
@ManCave
not to sure about GPU but every other device ive used with BIOS (from a hardware level) has a hidden BIOS ID number Example 2021 & each version increases.
Flashing the BIOS it will check this ID & if lower stops flashing to protect the hardware
Hence new BIOS flashed but older ones do not
2 Dec 2020
Boarding a Rocket Ship
Use version 5.127, this is best version for flashing as others can come up with errors like this.
OP
3 Nov 2021
Serbia
Yeah that makes sense... Is there a way to edit the original bios so the program thinks that the id is newer or the same as the current one?
OP
3 Nov 2021
Serbia
I actually managed to fix it by using nibitor and modifying the device id from 1200 to 1202 on the original bios file. FINALLY it works like before. Thank you for your devoted time and suggestions though!
19 Sep 2009
Riedquat system
What was the error btw?
Nice to see you fixed it though.
