*doffs cap, that looks super niceNew lights fitted for the kitchen diner:
Great to finally have rid of the grotty old chandeliers that were there when we moved in.
**** me. Seriously, scary is an understatement.
What's the back rats nest of cables serving?
How would it start a fire? It is wrapped in about 20 layers of insulating tape.How that hasn't started a fire I don't know. How hard would it have been to at least put it in some terminal blocks before wrapping? It'd still be incorrect, but better than twisting by hand!
Can't tell if joking.How would it start a fire? It is wrapped in about 20 layers of insulating tape.
Central light fittings are a nightmare to buy for. Those look pretty good! My Mum bought bird cage things once and we ripped her hard for it - ended up going back to the usual pendant style.
I'd have thought a bit of sanding would solve that, maybe paint it to try and reduce splinters?Walked past a skip and spotted a cable reel. I was about to end up buying a crappy beech effect IKEA table for my little one. This is much better as a craft/lunch table. Bevelled the edge with a router and then sanded. The edges are still a bit rough so a pint to anyone who has a genius edging solution... I'll probably end up layering up the top and bottom with MDF and then finishing the edge but then I am pretty close to just buying a table, lol.
Your drive looks massive.
