I'm on a smart meter, you have to have one to get on the "GO tariff", they take half hour readings, those readings are showing on the Octopus portal.
I thought with a smart meter you did not have to put in readings, bit daft if you do as they have half hour readings from you?.
Give them a call. If their system misses any half hour statements then it gets stuck.
