For some reason you posted Jumper's link instead of yours lolScore 23 586
Graphics Score 24 191
CPU Score 20 660
10980XE @ 5.2GHz
Asrock OCF 6900XT @ 2777/2150
Driver 21.7.2
https://www.3dmark.com/spy/23880699
Its all good, I initially thought I was going crazy hahaDoh. I was half asleep using it as a template
All corrected.
How come you are using 21.7.2, higher scores?
That might be because you are loading tuning profiles from older drivers? Assuming you don't change anything in the CPU side it should not prompt to restart.They have done something odd with profiles in 10.2/3 where it restarts the PC when resetting it. So I just leave it on 7.2 now, I am not sure if its higher scoring or not.
I need to pop the water block on next and re-run it.![]()
Here is my notebook, 3070 is capped to 125W at the moment so will be looking to expand that a fair bit. The GPU core clock is just a rough estimate as a result as it bounces a lot. Dynamic overclock set to +50Mhz core and +900Mhz mem.
Score: 10615
Graphics score: 10513
CPU score: 11236
9900KS @ 5Ghz
3070 Mobile @ 1600/7900
Driver: 496.49
https://www.3dmark.com/3dm/68133244
Not bad, you'll need to unlock the power limit with MPT to compete with the higher scores.22575 nice jump from 3090
https://www.3dmark.com/spy/24102800
2800mhz core 2160mem
[email protected]
2020-21.11.1
