Hi,
Currently using Corsair 570x case but feel it’s getting too crowded and looking to build a new cleaner water cooling system for my new Z690 build this time in the lian li dynamic xl with the EK front panel full distro plate. Hopefully will be easier cable management too.
Overclockers description says it can accommodate bottom 360 XE and top 360 PE rad from EK. Based on the images I believe this to be in either a pull or push configuration.
Was just wondering if I’d get better cooling performance from
360 SE push pull for bottom rad vs
360 XE push or push only.
Not sure if they’ll be enough space for an push pull on the top rad though.
looking to use the new ML 120 Elite Premium fans when they come out seem to have good SP and RGB not as nice as nice looking as the QLs but better performance for the rads.
Also anyone know if you squeeze in a third rad in the side panel? The more the better.
First attempt at water cooling in my current set up
https://~ibb.co~/vYqkT3Z
looking at something like this for the finished product but not sure on best rad configuration.
https://www.att-distribution.com/ou...-o11d-xl-d5-pwm-d-rgb-plexi.html#.YYr7qS3fW-o
