Ghosting of some sort when moving in games
Turn gsync off and test.
Also I hope you use vsync off in games with gsync on.
I've tried doing that, didn't do much difference.
Can't see big difference between fast and super fast, while extreme is unusable because of the insane amount of inverse ghosting and change in brightness.
But if I shouldn't use it with g sync then the monitor is worthless.
I didnt say that I said test it with gsync off. You need to try different things to troubleshoot the issue.
Also gsync only is needed if your frame rate drops to a certain low number. If you are getting 90fps+ in your games for instance gsync is not even being used even though it is turned on.
make sure whatever game you are playing you have onscreen FPS counter too to check its not an issue with sudden drop of FPS.
(I watched your youtube vid and I couldnt really see an issue)
edit: just watched the Youtube Doom vid. I can see the blur in the background but watch the gun. It doesnt blur. Thats doesnt look like a monitor issue. If it was the gun and the hand would blur too. Looks more like some kind of game engine issue.
Also are you using DP or HDMI ?
