Selling my RTX 3080 and upgrading to 6900XT for Forza 5????
Wouldn't be free for me as it's an Asus tuff 3080 oc just looked they're not going for as much £830... Blimey if they were offering me FE edition prices I would rip their arm off and have my 6900xt on order already lol
Same tbh, i would sacrifice RT for more raster performance any day. It's a no brainer!
If you can a profit on the change then go ahead. However, if you have to spend money to make the change, then no, it's not worth it for one game. I doubt you would notice the difference in game unless you were looking at an FPS counter.
Forza 5 everything maxed out to its highest setting @1440p I'm getting 90fps, so I can definitely notice fps if they are a nice bit higher.
Another bench showing the 6900 clearly faster in gameplay.
Forza Horizon 5 does feature a built-in benchmark and initially I was looking at using this for my testing today. However, while the benchmark delivers performance that is broadly representative of what you’ll see in game while using an Nvidia GPU, I found AMD GPUs performed much worse using the benchmark compared to what I saw when actually playing the game.
Take a look at the above chart for instance, for the RTX 3080, the delta in performance between the built-in benchmark and actually gameplay is pretty close, especially at 1440p and 4K. Taking 1440p as an example, the RTX 3080 performs just 10% worse in the built-in benchmark compared to my own test sequence. The RX 6900 XT however, performs 31% worse in the benchmark vs actual gameplay, making it a fair bit slower than the RTX 3080 – which just doesn’t match up with the actual gameplay experience.
https://www.kitguru.net/components/...on-5-pc-performance-benchmark-30-gpus-tested/
It's a good thing there's no bench thread, because you know which GPU would be topping it, the 6900 XT. :)
I wish people would stop posting GameGPU "benchmarks". They're literally made up. Digital Foundry already showed that the 6800 XT is faster than the 3080 in this game, let alone the 6900 XT.
(Skip to 15:50 for a comparison between the two.)
Made up? kitguru just confirmed their results using built in bench.
There is no in game RT, so no bickering.;)
I think there is RT, at least in some part of the game as there's an option for it in the menu.
The cars have RT, don't they? It's a basic implementation but I'm pretty sure the cars have RT on FH5.
Yes I think it's in there.
Why are you guys always bickering :cry:
All friendly here atm. It won't be if I start a bench thread though. :cry:
