Selling my RTX 3080 and upgrading to 6900XT for Forza 5????
All friendly here atm. It won't be if I start a bench thread though. :cry:
:cry:;)
Soundtrack for the issue.
Game runs beautifully on my 3080 @ 3440x1440 and 4k with max settings (extreme preset doesn't set everything to max, you'll need to go and turn a couple from ultra to extreme) and motion blur + FXAA off and MSAA set to 4x
3440x1440 - usually 80/90-110 fps depending on scene
4k - locked to 60 entire time
Not experiencing any textures not loading issues like some reported either, however, LOD is very poor but as posted already, developers have confirmed it is an issue.
There is no ray tracing in actual gameplay either. Reflections/SSR are very good here though tbf so not too much of a need for it but would be nice to have it on the cars and puddles but probably not been done because of the poor RT performance from RNDA 2/consoles.
Great gif usage. :cry:
There's no point since it will just get derailed like the last one and the moderators do nothing to stop so can't be bothered.
If someone else does it though I'll contribute.
Again, just don't make it bias for one side and you won't get called out by everyone thus no derailment ;) And as stated no RT is used here anyway so you have nothing to worry about :p ;)
Seems like nvidia is better then this time round only slightly in fh5
Im getting 98/100fps average pretty
High strung 6900xt
undervolted 3080ti fe seems to get 98 :/
So what do you guys recon is it worth selling on my Rtx 3080 and grabbing a 6900xt?
The only game I play loads of was Forza 4 and now Forza 5. My monitor is 1440p @ 240hz so always hungry for them extra FPS and the new Forza 5 is quite demanding. Do you think it would give me a nice bump in performance to be worth doing???
Forza 5 can run on a potato
On my rtx3090 I get 4k max settings, RT on, 8xMSAA and 65 to 100fps
High strung 6900xt
Make sure you are using 21.11.2, might have more performance for for Forza Horizon 5.
All the benchmarks posted have been done on the previous driver too.
Be great if someone on here with a 6900xt could post some benchie of Forza with these new drivers everything maxed @1440p. Would definitely help me decide.
