Enabling UEFI, wont boot into Windows 10 , goes straight into BIOS?
Underboss
20 Oct 2002
Oxfordshire / Bucks
Hi all
Curious to why enabling UEFI makes it boot into BIOS and not windows ?
I have a x570 Tommahwak wifi with the 3600 cpu
using the m.2 slot for my ssd
any ideas?
Fairly sure that a non-UEFI windows install won't have the required partition that the UEFI bootloader looks for, and as it can't find anything just loads the default UEFI shell (i.e. the BIOS)
As above, if you installed via legacy, you need to convert Windows to UEFI.
In disk management, for the boot disk, right click -> properties, is the partition style MBR or GPT?
If it's MBR you'll need to use MBR2GPT (built into Windows, via command prompt) to convert it and then change the BIOS settings to UEFI.
not sure i follow
Doing that, is the same way as going to exploerer and right click > properties on the drive, comes up with same windows, but i cant see anything in there that relates to MBR or GPT ?
not sure i follow
Under the Volume tab:
In that case you'll need to convert it to GPT. Just realised Disk Management does offer it from the same context menu (Should say Convert to GPT Disk), I would imagine that's the same as doing it via command prompt.
Highly recommend to back everything up just in case, and once it's done, make sure to go into BIOS and change to UEFI boot.
cheers
checked, and its greyed out, only available is convert to "Dynamic Disk"
