- 22 Feb 2021
- Lymington
Here’s a problem I’ve hit when installing a no-neutral, 2-gang, smart light switch into an existing 2-wire (UK) wall switch enclosure, which has PIRs wired in parallel:
When either of the PIRs (motion sensors) are triggered, this effectively shorts the two poles of the smart switch, so there is no voltage across them, hence they de-power and lose connection with Wifi / smart hub. Is there a work around to maintain power to the switch, hence keep it connected and allow the other gang to be operated?
I’ve seen this problem posted in a couple of forums, but no solution has been forthcoming...
