- 3 Sep 2003
Being the klutz that I am, I've managed to break one of the pins off my MSI B550m Pro vdh WiFi motherboard.
I was only using it for a 3.5" bay memory card reader / usb hub.
I take a reasonable "repair" would be to just fit a pcie usb 3 header card, then those use the ports on the pcie card instead to hook up the memory card reader?
Or just forget about the front panel usb connectors and go for an external USB hub and card reader instead?
I am very annoyed at myself though!
While I have seen replacement usb 3 header connectors on online auction sites for a few quid, it's probably not worth risking damaging the motherboard further!
Just a bit annoying as the motherboard and CPU etc isn't even two months old yet! I really don't want to spend another £90 on s replacement motherboard!
Has anyone else done similar, and how did they get round it?
Oh well, it'll do just now. Perhaps next year I'll upgrade the old HTPC, which currently which uses an Amd a8-6600K cpu & FM2 motherboard to a entry level ryzen and use the current motherboard from my main system for that build, upgrading my main rig to a full atx motherboard & perhaps a bigger and better case too.
