Water leak under kitchen floor - Poor pipe repair and left in a bad way.
19 Sep 2016
Jensen's Leather Jacket
Evening folks, wanted to get some thoughts on a little situation that's cropped up.
We had a leak under the kitchen floor which was caused by the rubbing of a pipe creating a small pin hole sized escape route for our cold water - the time scale of how long it was going is unknown since it didn't change the behaviour of anything in our house.
I noted the start of a damp smell last and noise Tuesday morning and investigated by pulling up the floor to check after ruling out other potential causes and was met with water under the Lino so immediately turned off the Water. At this point I called British Gas as I have home care including plumbing and drains cover and they sent out someone who pulled the Lino off and confirmed there was a leak.... I know..
On Friday the British Gas supplied plumbing co. came and cut into floor boards, cut out the leaking area on the pipe (it had been rubbing on another pipe causing the eventual failure) and swaged on a new fitting to remedy the problem.
I was then told that the £1,000 cover which under the policy states "Up to £1,000, including VAT, for getting access and making good for each repair" (BG policy NOT my home insurance) would not be enough to replace the needed floor boards and it would be an insurance job and he left it there.
It was the missus who dealt with the plumbing co and she didn't sign anything off - we are waiting for an email report to come through tomorrow. When I finished work and inspected the repair this is what has been done.
I have a dehumidifier for boat stuff which can pull around 50L a day and the humidity level of the room is around 30% (nice and toasty too) but the whole episode seemed a little off to me. I spoke to my plumber and a friend who is a joiner to come and give me an assessment over a cuppa so I would know what I'm getting into if we went the home insurance route but came to a different conclusion to the BG plumbers.
We took up the floors in the adjacent rooms to asses the state of the chipboard there (all dry) and also under them to check for standing water on the concrete and found nothing concerning, as it looks like it was contained mostly to the area where the pipe has failed. The joiners opinion was yeah other than replacing the chipboard floors where there had been water its should fall within the £1k to make good the repair blurb..
The plumbers opinion was more scathing, not of the scale of the repair, he agreed with the joiner that its not as bad when the water damage was localised to the areas it was, but more the actual repair itself is problematic.
A smaller diameter pipe was put in place to try and reduce the contact with the lower pipe (the piping here gives me the chills as an Engineer tbh) but the fact the repair was done so close to the lower pipe and the top of new fitting now touches the level where the underside of the chipboard flooring will be means that as soon as a new floor is laid, it will be pushing down on the fitting and then the new pipe will be right back down on the pipe below - with more force than the original solution and a timebomb waiting to happen.
He advised that if it was him the repair should have been done way further back so that there was more flex allowing for a rubber shim or other protective surface to be installed between the pipes - metal on metal is never good!
Their opinions aligned with mine that the repair was potentially hazardous and the fact that it was left as it was appalling for something which there should be cover for.
I've not touched the kitchen since other than running the dehumidifier as I think that it's up to them to make good on the repair. I've no doubt that I would get a solution form my home insurance as we have a decent policy in place, its just that belief that it should be more than covered under the Plumbing specific policy we have with BG that makes me not want to submit my 1st claim under the home insurance and then be paying for it for years to come if I dont have to.
FYI the concrete is bone dry now, the timber joists which where wet with the leak have all dried nicely and the chipboard while ugly has retained its shape (bar the one right under the leak) and apparent strength with no bounce - ill still be replacing these regardless.
Another thing to note is that while the chipboard on top was wet, it was only upto the edge of the lino which came just shy of the units all round due to a trim piece meaning very little discoloration of the boards under or around the units.
The edge of the units also appears to be on joists with the chipboard flooring having its ends (bar one) on that joist - in total 5 standard size chipboards would be needed to replace the previously wet ones and something that could be done without touching the units.
So am I being unreasonable? is that a state you would expect something to be left in by a plumber? Is the fix sound or just a half baked solution which should be done better and are they trying to wriggle out of the making good on the job part of the policy... I know the answer to that last one :D:rolleyes:
I suspect the plumber said the floorboards aren't included because they don't fancy or know how to replace the floorboards.
Obviously make sure you see their quote, as unless they were there for most of the week, I don't see how they've done £1000 worth of work.
Also replacing the floorboards given your description doesn't sound like much work even for an inexperienced person. I cut out some old proper floorboards, chiseled and leveled a joist and put some chipboard flooring down in a morning. (DIYer)
You would have thought your British Gas policy would cover the first £1000 of any repairs, not be a case of it's going to cost £1100 you're on your own?
Btw what the plumber did isn't a swage fitting, they've used a 22mm to 15mm compression fitting. I would have expected them to solder it as that way it wouldn't have protruded as high.
Also chipboard has a tendency to soak up water like a sponge causing it to expand then crumble when it dries out so I think you are right to replace them all.
The pictures don't really show how swollen the chipboard floors are. Aside from the bit that was cut out, are the rest still actually flat or have they swollen with the water ingress?
If they've swollen then most likely the entire floor is going to have to come up. You'll have a complete nightmare trying to "patch" a tongue and grove flooring. The "patch" is going to move differently from the rest of the floor / it will never be level.
My parents have actually faced this exact leak type this year, insurance company has said the entire floor needs replacing since you'll never get the T&G to sit flat again properly.
As for the repair itself, to be fair British Gas have stopped the leak and allowed you to turn your water back on again. It's emergency cover and I wouldn't nescessarily expect them to "make-good" the rest of the kitchen.
We had the exact same problem earlier this year when we was due to have a new kitchen fitted. We'd just moved into the house a few months prior, had a new dishwasher installed. I noticed the week before new kitchen was due to come in, the laminate felt spongey and felt water oozing out onto my feet when walking near the sink...
Turns out the valve on the water connection to the DW was naff and dripping onto the flooring and down a crevice straight onto the floorboards. Must've been like it for well over a month at least, the water was quite substantial, I ripped up parts of the floor like you and noticed the exact same. Soaking wet insulation, ripped it up, soaking floor boards and swollen. It had covered probably a very similar space as yours has.
Spoke to our kitchen fitter, decided he'd replace it when he starts the kitchen rip out. I'd rip up all the wet area and insulation, let the floorboards dry out for that week before he was due to come. Checked no resting water on the concrete underneath fortunately was fine. It all dried up pretty well and was bone dry by the end of the week.
Then the Monday he started he ripped the kitchen out first - followed by the floor boards, popped to timber yard got all new boards and he replaced them. Probably only took him 4-5 hours and that included ripping out our kitchen, going out for the new boards getting back and laying down new again. He charged me the floorboard cost (think it was about £250) + extra £100 odd on top of his kitchen fit fee. Wasn't worth a home insurance claim at all.
I'd definitely say £1k+ is highly excessive for the labour involved, it looks bad but the repair isn't as drastic as it looks.
That damaged floor goes under the kitchen cupboards though, so to replace those damaged parts likely means removing the carcasses, which probably means removing worktops etc.
Jobs like this can snowball VERY easy.
So regarding that, there is a very clearly defined line where the OG lino was an where it was retaining the water underneath. The areas near the units are the least damaged and now that they are dry they are all flat.
My Plan would be as follows.
RED - Exisiting Joists (also joists running horizontal along the length of the boards as expected too)
GREEN - Additional Joists to be added to become the new "end" and support the end of the boards where cut.
BLUE - 4 new flooring Panels
Cut away the area in Blue, add in 2 additional joists along the sides which act as the "new edges"
Ideally with T&G everything will be interlocking so by treating it as 4 new sections of floor with new starting joists etc we would get that continuing flatness on the repaired section and would be able to make sure that everything is level.
I wont be replacing with Lino, instead will be using Laminate and underlay (toying with 3.2mm hardboard on top if required) so should be able to get a level surface fairly easily one way or the other.
Just to be clear, i'm in no way expecting the BG cover to pay for any of that, but in making access, they did cut into and remove parts of 4 boards in total which I believe should be replaced under the policy since there was no damage to the kitchen prior to the leak
"Getting access and making good In addition to the cost of parts and labour, our insurance products and our non-insurance service and repair warranty products cover up to £1,000 including VAT for getting access and making good.
We won’t be responsible for repairing any preexisting damage, nor will we replace or restore the original surface or coverings, for example, tiles, floor coverings, decoration, grass or plants."
Thanks for the clarification :D only pipework i've worked with is swagelok and thats burned into my head!
Grand total of 70 minutes across 2 visits. 1st to say its a leak and a second appointment under an hour to implement a fix.
I think you're mixing home cover versus home insurance? Home cover is to stop the urgent need, not provide a proper fix. It's now over to you.
1 grand to replace a small pipe? Thats a nice job if available.
I would get back on to BG, tell them you will cancel the scheme if all it covers is minor repairs.
To reiterate this isn't the main policy, this is just the home emergency cover where they get any lacky in a van to do a quick repair. How much the lacky invoices is between him and BG and their agreed rates for the type of job.
Yeah but thats not his problem, thats BG's problem, ultimately this emergency cover is barely worth paying for, only a minor amount of work carried out.
I somewhat agree as I've got similar with Admiral and the jobs they're allowed and to what quality is poor. They've refused to do two minor things for me as it wasn't 'emergency enough'.
Tell me how much it costs to get an emergency plumber out to do that job though and I assure you it was cheaper.
yeah slightly different some scrote attempted to break into the house via the front door couple of weeks ago leaving us with a damaged un usable lock. rang insurance for emergency cover they sent a locksmith who fitted a temporary lock.....(chocolate teapot comes to mind as ended up putting two timbers across the frame to secure the door , when he had gone).
then when we rang the insurance the next day with a crime number they sent the same company , but another branch to asses and measure up for a door. we had no excess to pay for emergency cover (on lock) but excess on the door claim and so called betterment fee hmm.
they fit door hopefully on 10th dec.
wouldnt be without the peace of mind....trying to get a trade out is ni on impossible in normal hours. dont care if home insurance is 100 pound more just bang it on.
That’s a home insurance job if I ever saw one and I don’t know why you wouldn’t go down that route.
I’d be wanting them to replace the floor for the entire room and fixed the pipe work correctly. That 15mm pipe was likely 22mm for a reason and it’s now restricting the flow rate.
They’ll inevitably have to change the kitchen as well while they are there as it will require stripping out and it will never go back the way it was, lots of it will be gluded like cornices and worktops. Happy days?
It really doesn’t matter how much the claim is, the impact is that you claimed. House insurance is cheap, use it.
