I tried running Timespy Extreme on my system today and noticed that my graphics score had gone down from ~10700 to ~9900.
I use MSI Afterburner to undervolt my 3090FE and when I checked the settings it showed that my GPU was running at stock and no profiles were defined.
I then checked the Profiles folder within the Afterburner install and noticed that there was a new ".cfg" file with a slightly different name which contained no profiles.
The name of the new "empty" config file was:
VEN_10DE&DEV_2204&SUBSYS_147D10DE&REV_A1&BUS_11&DEV_0&FN_0.cfg
and there was another older and larger config file called:
VEN_10DE&DEV_2204&SUBSYS_147D10DE&REV_A1&BUS_7&DEV_0&FN_0.cfg
When I opened the older config file in wordpad I could see my profiles.
I then tried renaming the older config file to the name of the new config file (by changing "BUS_7" to "BUS_11") and restarted Afterburner and all my profiles were back and so was my Timespy score.
The date on the older config file (before I renamed it) was from Thursday which just happened to be the day I updated the BIOS on my Aorus B550i Pro AX. It looks like when I updated the BIOS it changed the PCIE BUS identifier which is returned for my GPU and that stopped Afterburner from recognising it.
I don't remember ever having to do this before with my previous Intel setups. Is it normal for a motherboard BIOS update to change the PCIE BUS ID?
