Re-assembling my 2009 Mini I found I had snapped the aerial cable.
I can't tell (too small) if cable is single or double wires. If former I can solder the join I guess... if latter whats the easiest and cheapest way to effect a repair. WiFi works with the other antenna but I'd like it to be fixed
Image if that helps anyone advise me
If anyone has any links that are postable that would be great for bits to buy?
