What are you using to drive the K702's? They are low impedance but are very insensitive so need a fair bit of current to sound their best. If you can drive them properly then you've bought what are probably the best gaming headphones on the market.
Errrr nothing yet, I'll take a suggestion.
Edit: just read a lot saying FiiO E10K is good.
EDIT 2:
They turned up today, I will definitely need a amp/dac whatever you call it, but the FiiO E10K is already on its way and should be here tomorrow.
That being said, although a bit quiet (because of lack of driver) and lack of base (which the driver also has a boost for) I can tell straight away that these are far far superior in sound quality to the AKG 371BT - which are definitely going back now.
Apaprently they get better after a break in period also, cant wait.
The FiiO E10k is good for the money but it's a Stereo DAC & Amp which means you'll just be getting straight stereo instead of virtual surround in games.
What you need is something like the Creative SoundblasterX G6 which is an external USB sound card which will have all the bells and whistles needed for gaming. They are around £115 but can be had cheaper as B stock direct from Creative.
If you're using the FiiO E10k you feed it using USB, which completely bypasses your motherboard sound circuitry. In order to utilise your motherboard sound you would need to either use an optical feed to the E10K, which it doesn't have, or line out audio fed to the E10k, again, something it doesn't do.
Link to B stock G6 - https://uk.creative.com/p/b-stock/sound-blasterx-g6-b-stock
The bonus is that the G6 is also just as good as the E10K at stereo and, so you have a pretty decent stab at both worlds with the G6
Sony MDR-G45. Sounds great when its been EQ. Really rare find this type of headphone.
Wow I had a pair like this many years ago. Don't know why you want to use these now but hey ho.
